Airbrush Paint Finish
Guest -
GuestComment
Sorry about not answering you all. Suddenly got busy plus I wanted to try some of your suggestions out and see what worked. Temperature seems to play a big part. I am in my workshop and I have a portable heater but clearly it doesn't get as warm as indoors. During the summer it is sweltering and I cannot recall the problem. Not sure about the detergent because I tried a test piece, thoroughly washed and rinsed it and still had a bit of a problem. I think I have come across one problem/solution. Vallejo paints need a LOT of shaking before use and I mean a lot. Whether that is a temperature thing or what I don't know. Nearly got RSI shaking the last bottle lol. Within the next couple of days I will be using Zero paints for the first time so will make sure they are ok by temperature and I am also aware that they are lacquer paints. Steven000 I am going to try your idea with alcohol (hic), I have some 99% ISA so will try that. I will report back and if anyone has experience and advice re Zero paints I would welcome them.Comment
