Bleeding
  • meirion658
    • Jan 2023
    • 22
    Bleeding
    Afternoon all,
    As I'm new in the world of Airbrushing I seem to be having issues with bleeding when masking up! Which is causing me grief!!
    The masking tape I use is Tamyia and the paints I use are AK 3rd Gen.
    Any advice tips on how I can stop this in future? I do press the the masking tape down firm so I wonder if the paint is thinned down to much
    Thanks all
    • 16296
    It's a potential problem for everyone so your not alone. The only things I can say is burnish the edges of the tape and try not to spray towards the tape edge. You're right in suggesting that thinner paint is more likely to bleed under the tape.
      • 18302
      Paint might be thinned ability much but that should show when you spray.
      One trick is to do a light coat for the colour you have masked over. Some use a clear coat. Then when that has filled the 'leaky' bits, spray the second colour.
      • KarlW
        • Jul 2020
        • 1522
        Cutting a fresh edge on the tape also helps, stick tape onto a piece of glass, use straight edge and fresh blade to remove the existing edge.
        Useful on older rolls that have been abused a bit.
        Also, just as when spraying without masks, build the colour up in layers, better a few light passes than one heavy pass.
        • Andy T
          • Apr 2021
          • 3239
          The trick mentioned by Ian is a great one, then go very lightly at first with the "new" colour to further seal the edge.
          As Karl says, building up thinner coats is best too.
