Help!
    Help!
    Any ideas?
  • Andy T
    • Apr 2021
    • 3239
    You seem to have edited out your question.
    From what I saw last night I'd wager on a problem with the paint. Have you tried giving it a good stir just in case it's settled heavily and shaking doesn't cut it?
    I'd try stirring for a minute, letting it sit for 10 to homogenise, then stir / shake again.
    Has it got really cold at any time? Anything below about 4°C can ruin water based paint.
    • Gary MacKenzie
      SMF Supporter
      • 1059
      • Gary
      • Forres , Moray , Scotland
      Originally posted by Magneto
      Any ideas?
      Any ideas about what ?
      Are you having a problem ?
        Yes, with my airbrush
        • Gary MacKenzie
          SMF Supporter
          • 1059
          • Gary
          It helps if you explain what the problem is , because without any idea the first questions would be
          1. is it attached to a compressor?
          2, is it set to the correct pressure for the paint ?
          3. what paint ?
          4. have you thinned the paint ?
          5. if so , what make and model of thinners did you use ?
            • 18286
            Any ideas?
            Going to need more info to get to the bottom of this.
              I’ve attached the airbrush to the compressor now and it seems to be working fine now. Thanks
              • stillp
                • 8224
                • Pete
                • Rugby
                That usually helps.
                  Originally posted by stillp
                  That usually helps.
                  Only if the compressor is switched on, otherwise you won’t get far :thumb2:
