Hi All,
I am afraid I know very little about air brushes and compressors, my husband has just re-ignited his passion for model making and is currently working on some WW2 aircraft kits he has bought.
I am desperately searching for ideas/ help as I am thinking of trying to buy him an air compressor kit for Xmas as a surprise.
I have seen this kit for sale on the internet , it is retailing for around $175 Nz dollars which is around 85 pounds. I probably can't afford to go much more above this but was hoping someone could have a look at the specs and advise me if i was wasting my money or if this was a good starter model.
Any ideas/ sugestions would be greatly appreciated.
AS18-2 AMPRO AIR BRUSH COMPRESSOR 2010 Model RRP$ 399
and AIR BRUSH SET
THIS IS BRAND NEW MADE BY AMPRO (American Professional) TOOLS
New Model now has auto stop, and bigger motor and more air flow!!
A quality diaphragm air
compressor, with a high
output designed for airbrush
spraying.
Very quiet running, compact
and lightweight.
Complete with Filter
set up for a constant flow of dry
air. And Reg
• Double cylinder, high air flow,
• Oil free, piston type, no air polluted
• Power: 1/6HP
• Air Flow: 20-23L/min
• With pressure gauge and air filter
• Auto stop, start at 43PSI/3bar, stop at 57PSI/4bar
• Special pressure is adjustable (REG)
• Connect with 1/8"BSP
• Dimension: 25.5*13.5*20.5cm
• Weight: 3.9kg
Complete with Air hose and Air brush twin Holder
240 volt
THESE ARE A GREAT COMPRESSOR< ONLY JUST BACK IN STOCK!!!!!!
Trade Quality
Light and Compact
Now with Airbrush Set
AIR BRUSH SET
* Durable Double action trigger
* Versatility produces the ability to paint fine lines for pinstripping, graphics, detailing, modeling and more
* Fluid delivery type: Gravity
*15-50psi
Cup 20cc and 40cc
0.3 Nozzle size
and AIR BRUSH SET
spraying.
and lightweight.
air. And Reg
• Power: 1/6HP
• Weight: 3.9kg
240 volt
Trade Quality
Light and Compact
AIR BRUSH SET
*15-50psi
Cup 20cc and 40cc
0.3 Nozzle size
