Hi all,
Wonder if anyone can help or advise me on what I'm doing wrong.
Whenever I'm airbrushing the wing to fuselage section of a model, in this case a 1/48 Spitfire, I seem to suffer from a rougher finish than the rest of the model surface. It's not massively rough but you can see the difference when reflecting in the light.
I'm using a Badger 200 airbrush with compressor set at @20psi, holding the airbrush between 1.5" to 2" from the surface, the paint mix is approx. 60/40, the paint and thinners are Tamiya.
Strangely enough one side seems worse than the other and the only difference was I turned the model upside down to spray the better finished side.
Anyone have any tips to remedy this?
Atb, Colin.
Atb, Colin.
