had a airbrush with my as80 compressor i think it was only a cheap china one and i broke the nozzle whilst over tightening it with the spanner. I looked on ebay and found a nozzle and needle replacement so i bought it thinking it would be the same.
Now the airbrush sound like its spluttering and even with water sprayed through its not an even coat more like the orange peel effect. I took out the nozzle but my spanner didn't fit. lucky it was only hand tight.
I tried again still same problem. It also seemed to lack pressure so i turned it up to 30 psi but still came through low pressure until i took off the nozzle cover then i could feel the pressure. I am thinking that the new nozzle is too long or maybe the needle comes out too much and blocks the airflow. Do i continue to spend money repairing it or get a better one with reliable spares.
I was looking at the VEDA WD-180 AIRBRUSH or the TD-183k Gravity Feed D/Action 2/5/13cc Cup Airbrush Kit w/ Air Connector Filter any views on these its my price range.
cheers Gaz.
cheers Gaz.
