The nozzle of my Harding & Steenbeck Cr2 Plus AB was stuck in the aircap when I went to clean it this afternoon after I used it for the first use since about 8 weeks ago. (To be clear, by "aircap" I mean the part that fits over the nozzle and screws into the body of the AB.) The nozzle has always been a quite loose fit in the aircap. I always thoroughly clean the AB after use including using the tiny bottle brush up the spout, usually finishing with the ultrasonic cleaner which I used last time. I had to use tweezers to loosen it. It seemed clean although it had developed a brown colouring over the last 15 months since new.
I also noticed that the needle had become stuck in the body of the AB. This has never happened before. I was able to quite easily tug it out of the back using fingers.
EDIT: I have just remembered that the last time I used it, it was with Tamiya Synthetic Lacquer (solvent = Cellulose Thinner).
Any ideas on how to prevent these two? A little lubrication, and with what? Even deeper cleaning, and how? Keep the nozzle separate until use?
By the way, I once watched a film on how to deal with a stuck needle badly gooed up with dried paint. The user removed the AB handle and banged the end of the needle (the blunt end of course) quite hard on the table. Obviously, the nozzle must be removed first or else it would be shattered by the point.
