Can some please let me now the best setting for the compressor as I new to all this I have been useing it on 30 to 40  cheers
					Best setting for compressor
	GuestTags: None -
	Guest -
	Guest -
	Guest -
I am too mate. I use mine on about 12 - 15 for camo patterns, and about 20 for big area priming. Seems to work ok for me, but I am new to it, but it is a good starting point.Originally posted by \Im only a noob mate! But loving the learning curve!Comment
It depends on various factors,not least of which is how you thin your paint. I'd say 15psi is a good average but see it as a starting point and work out what gives you the best results. I spray from about 10-12psi up to about 20-22psi depending on the paint and what I'm doing.
There's that echo again lol!Comment
I use 15-20psi but the higher your psi the quicker the paint will dry on the needle tip, keeping it low will prevent it.Comment
As others say and per steves, it's dependant on more than just pressure, how thin the paint is you're spraying, the brand, type of thinner etc etc
I typically spray tamiya acryl's at 15PSI - ish
Humbrol enamels at 25PSI - ish
Best thing to do is practise your thinning to that 'milky' consistency then practise on anything to hand, empty milk bottles, plastic boxes, scrap sprue etc, play about until you find a setting that works and you can control it well, use the figures given so far as starting points and see how you go.
I'd recommend the Geoff Illsley DVD for painting tips, my wife got me that a couple of years ago and it's fantastic, talks you through the thinning, loading, spraying, cleaning of various different paint typesComment
I'm still finding my way round, but I have found 10 - 20 psi is good for camo features and small objects. Big spray areas +30psi will suffice.Comment
