Help with washes
    Oww, forgot to mention i thinned the poster color with a drop of dishwashing soap.
    • dave
      • Nov 2012
      • 1830
      • Brussels
      #17
      I use a mixture of oil paints thinned with an odourless thinner, Vallejo off the shelf washes or I make my own with the Daler Rowney FW inks.
      The recipe came from a US site "awesome paint jobs";
      15mL Matte Medium + 15mL 10:1 Distilled Water:Flow Aid and then about 40 drops of the ink colour I want. Flow Aid helps break the surface tension and is the "neat" version of the component in washing up liquid that makes it have that effect.
      On an economy note I use good quality oil paints, which are pricey (~£7) but one tube lasts a lifetime. So you can buy as you need start with one or two and add as you do different models which require different washes.
      Varnishing before washing is not essential; but it makes it easier to clean up overall washes and to correct mistakes without damaging earlier paintwork.
      • Peej
        • Aug 2014
        • 919
        #18
        Thanks everyone. Loads of info to be going on with.
