Dark metallic grey
  • HjnA
    • Apr 2021
    • 6
    Dark metallic grey
    I have to building sets that recommend dark metallic grey. I can not find that color from either Tamiya, Ak or Vallejo. Any recommendation?
    Sounds like gun metal grey would do you.
    • adt70hk
      • Sep 2019
      • 10436
      Hans
      It's a bit old fashioned but I sometimes use Humbrol's enamel gun metal H53 for this sort of thing as I have a tin from when I first came back to the hobby.
      They do an acrylic version but I've not used it so I can't say how it compares.
      ATB.
      Ps welcome aboard!
      • HjnA
        • Apr 2021
        • 6
        Thank you for the answers. I will try your suggestions.
        Is there a way to get colormaps for the different companies for free? I live in Norway and I have not find any store that sell them
          There’s a thread about that on the forum.
          • peterairfix
            • Jul 2012
            • 11080
            Try XF56 metallic grey
            • HjnA
              • Apr 2021
              • 6
              I tried that one, but it is a bit light.
                Vallejo Burnt Iron
                • Airborne01
                  • Mar 2021
                  • 4026
                  • Steve
                  • Essex
                  Morning Hans! There are a range of colours from various manufacturers that loosely cover your requirements; of course their use is dependent on what part of the model they are going to be used on. Some that I use are the Humbrol Metalcote series 27001 to 27004 (although some are described as aluminium they are inter-mixable to the precise shade you want - and are buffable to an appropriate lustre. Humbrol metallics 53 and 56,are useful, Revell 99 is also very dark. Acrylics are a happy hunting ground for you; War Front (Scale 75) Black metal SC-63, Model Air (Vallejo) 71.072 Gunmetal is good for washes. AK Interactive do a range of metallics and are excellent! I have all of these on my shelves and use them as and when required; although generally I create my own shades using a mix of a mid-spectrum metallic, a dark grey and a touch of blue, brown or green, A wide range of 'dark metallic greys' can be created. I mix in bulk initially using mini jam jars - the type you get from cafes, B&Bs, or hotels - then 'tweak' them as appropriate, I hope this is of use - happy hunting
                  • Mr Bowcat
                    • Dec 2016
                    • 4622
                    • Bob
                    • London
                    Just to add to Steve's list, Mr Hobby also do an iron and dark iron buffable. Both available from John.
                    Si vis pacem, para bellum.
                      Hans you could try https://www.modelshade.com/paint-conversion-chart. That's helpful
                        • 18940
                        Failing all this, and useful if you don’t know what you are looking for, search for paint charts by the manufacturers. Vallejo charts are found here, for example....
                        and Tamiya here,...might need to navigate the site a little..
                        Tim
                        • Del640
                          • May 2020
                          • 1151
                          Vallejo model air gun metal. Lovely deep metallic grey.
