I've done more experimenting, and found the root of my problem - not using the right thinner. I had been thinning my acrylic with water first (very bad - because it beads on an enamel base) and then windex, which stopped the beading, but I think was drying way too fast, and not wiping off the flat areas as well. I tried a whole lot of different methods on test pieces, and as soon as I used the right thinner for the acrylic wash, it went on much better, and wiped off much better too, even with the matt base coat and no gloss coat between. The acrylic gloss with an enamel wash is something that I am keen to try in the future, when I get some acrylic gloss, but I'm getting good results for what I need in my current project. I also noticed that while my turps was just stripping the enamel base coat right off again, the enamel thinner is much milder. It will still strip an enamel gloss coat, but much more slowly, and requires a bit of rubbing.
Anyway, time to strip back some major parts of my model and give it another go. I could maybe get away with painting on top of what's there, but that's going to give me a lot of layers of paint, and maybe not so good a result.
Thanks for your help - I've certainly learned a lot!
