Alclad airbrush cleaner
    Hi folks, a question for alclad users, is there any other airbrush cleaner that will clean the remenants of alclad out your airbrush, or do you specifically have to use alclads own.
    scott
    If your airbrush can take it, cellulose thinners will clean anything Scott
      Could I use nail varnish remover with acetone to do the same job?
      scott
        I dunno about using acetone - hopefully that's your better half's supply you're considering using!
        • rickoshea52
          • Dec 2011
          • 4076
          • Rick
          I've used nail varnish remover to soak a nozzle in that was blocked, don't know about using it on any of the seals.
          • john i am
            • Apr 2012
            • 4019
            After using alclad in my iwata tr2 I immediately strip it down clean and flush all parts with normal airbrush cleaner and dental brushes reassemble flush n blowback job done. Every now and then I put it through my ultrasonic cleaner for a deep clean. I've heard some people use windscreen cleaner but not sure how effective this would be but have considered it myself. Hope this helps cheers John
              I've been using acetone nail varnish remover for ages through my brushes and they are all still ok, just wondering if the acetone will clean the alclad.
              scott
              • Adrian "Marvel" Reynolds
                • Apr 2012
                • 3008
                I've always used Alclad cleaner when using Alclad colours, never had any issues and certainly don't have to strip my airbrush down after use.
                Adrian
                • colin m
                  • 8800
                  • Colin
                  • Stafford, UK
                  I have a H & S 'something' airbrush and use cellulose thinners for cleaning after Alclad and am always amazed at the stuff that comes out.
                    • 18272
                    I use cellulose thinner for the job. Works a treat. A lot cheaper than the Alclad cleaner and does not stink as bad. Yes it smells but I found the Alclad one really evil! (even with a mask on).
                    I don't think window wash will do it as there is only a small amount or spirit in it. It works for acrylics though.
                    IanM
                      lacquer/cellulose will do the trick. If you can't find that, use Mr Colour cleaner
                      • stona
                        • Jul 2008
                        • 9889
                        Lacquer thinners is a mix of solvents and varies considerably from one manufacturer to another. I would imagine an acetone based nail varnish remover might be worth a go with Alclad. If it doesn't work just about any lacquer thinners certainly will, as others have already said
