Hi peeps, I've just moved over to modelling armour and to using vallejo model air acrylics, I had intended to airbrush these as I'm so used to airbrushing paints normally on to model car bodies, but now my airbrush has gone belly up, I'm wondering if I can use my vallejo paints with a hairy stick without any detrimental effect to the finish of the paint, i.e no brush marks.
Can I brush paint vallejo model air paints?
I'm with Peter. I brush paint both Model Air and Model Colour. The only difference I find is 'Air takes a few more coats than 'Colour', but the end results are the same....so take's yer choice!Comment
Originally posted by \Vallejo model air brushes superbly....and I never get any brushmarks.
P.S. .........what part of Hampshire are you located, I miss the area, I used to live in Winchester, worked in Eastleigh and Basingstoke in my time. Used to do lots of deliveries around Fleet, Farnborough, Farnham, Cove, Basing, Hartley Witney. .....All over really!Comment
Originally posted by \That's good to know, so you would recommend using them on armour?............I was wondering about how successful applying camouflage would be, but then I realised that most camo is applied by brush anyway, more so in ww2. My wife made a remark to me as well........"what did you do before you had an airbrush years ago".........my reply, I used a hairy stick.........she laughed as she misconstrued what I meant by a hairy stick, I explained and she said well use one of them. I'm trying to not spend too much on this hobby as it is just a hobby, so if I can avoid using an airbrush then I will, they are so bloody frustrating at times!
And if you are looking to brush paint camo and want a soft edge...... try stippling the edges with Maskol applied with a bit of sponge....then just rub it off when the paint is dry........ There are a couple of tutorial videos on you tube.Comment
Originally posted by \I'm with Peter. I brush paint both Model Air and Model Colour. The only difference I find is 'Air takes a few more coats than 'Colour', but the end results are the same....Excellent.Comment
Originally posted by \..... and Miaggi San Ron gets bloody good results with his brushes too.Comment
Originally posted by \I'm in Farnborough now Dave..... Work in Bordon
And if you are looking to brush paint camo and want a soft edge...... try stippling the edges with Maskol applied with a bit of sponge....then just rub it off when the paint is dry........ There are a couple of tutorial videos on you tube..........I like the idea of going back to old skool ways!.......We all need a rewind sometimes.
Bah! Hairy stick painting.... Im probably more useless at that that i am at modelling, and painting.....actually im
Just Useless!
To be fair, i suck at painting by brush anything bigger than the figures, so i stick to the old blowjob gun. Plus its a challenge for me to learn the art of airbrush. But if someones able to brush paint well, im in awe!Comment
I'm going to have a bash at this brush painting malarkey, I've had to remove my sad butt out to the garage to do my modelling primarily because of the smell of enamels and white spirit, I got one of those humbrol workstation things (only good thing humbrol does these days) so that I can sit in the warm and watch 'quality?' telly. So if I can avoid going out to the garage in the bloody cold and stay in the snug warm then I will, it's a no brainer. Also, with money saved on not buying a replacement airbrush, I can get a few more vallejo paints and some more hairy stick paint applicators!
Originally posted by \Bah! Hairy stick painting.... Im probably more useless at that that i am at modelling, and painting.....actually im
Just Useless!
Just Useless!
To be fair, i suck at painting by brush anything bigger than the figures, so i stick to the old blowjob gun. Plus its a challenge for me to learn the art of airbrush. But if someones able to brush paint well, im in awe![/quote
Attached FilesComment
Originally posted by \Brush painting just takes a bit of patience and a bit of work. This was brush painted. Not perfect but not bad. A lot of cats ans a lot of flatting down.......
[ATTACH]139014[/ATTACH]
I'm being converted slowly, I used to be an enamel loving, airbrushing, car modeller. ........look at me now......... armour modelling with acrylics using a hairy stick.........One end of the rainbow to the other!Comment
Originally posted by \Crikey, that looks stunning. I think the last time I brush painted I was a lot younger and with less choices of paints......humbrol and airfix, so the results were not so good.
