Help, decalfix is eating my paint!
  • Mr Bowcat
    SMF Supporter
    • Dec 2016
    • 4697
    • Bob
    • London
    Hi guys,
    I'm having trouble putting the decals on a Tamiya spitfire. I've tried twice now, the first time I varnished with pledge, and the 2nd with Xtracrylix.
    I'm putting the decals on with decalfix, however it's eating into the paint. What am I doing wrong?
    [ATTACH]280572[/ATTACH]
    Any help is appreciated.
    Bob
    Si vis pacem, para bellum.
  • tanktrack
    • Jun 2012
    • 1429
    Hi Bob i haven't heard great reports about decal fix ,but did use it on a heavy corrugated area and it worked a teat , i do tend to use micro sol or vallejo decal fix , i also tend to leave my models for a number of days before fitting decals to allow the paint to cure along with the sealant ie vallejo matt or klear .
    steve
    • Mr Bowcat
      SMF Supporter
      • Dec 2016
      • 4697
      • Bob
      • London
      Cheers Steve, I did only give each varnish overnight, although the Xtracrylix says in dries in 15 minutes?
      • Paul Davies
        • Apr 2014
        • 284
        it might be dry to touch in 15min but a lot of paint and varnish will take at least 24hrs to actually cure properly.
        I would leave it for a day or two before trying to using decal fix on it.
          Bob these products might be dry in 15 minutes or whatever, but there's a big difference between dry & cured.
          Any decal softener uses some kind of acidic solution so there's always a risk that it'll eat into paint or a varnish that's not cured.
          Simple rule of thumb is allow a minimum of 48 hours before applying the decals - the longer the better really.
          Unfortunately in today's world, most products encourage modellers to do everything too quickly, with often unhappy results.
          Good luck with sorting it out.
          • Mr Bowcat
            SMF Supporter
            • Dec 2016
            • 4697
            • Bob
            • London
            Cheers gents, I'll repair the damaged paint this afternoon and re-varnish tomorrow. Might try W & N Galeria this time.
