I recently bought my first Airbrush ever- the Iwata neo CN. I bought this out of the favourable reports and the not so pricey cost. Additionally, I bought the replacement needle. Any thoughts on this Airbrush??????
First Airbrush Purchase
GuestTags: None -
Hi John, nice to see you back on the forum. Airbrushing eh? Nice one. I am still rather new to AB myself and have had to knock it on the head due to nowhere to do it at the moment.
The Iwata Neo CN is a nice brush though, two cup sizes, although I would stick with the smaller one, easier to manage paint and you can top up if needed. One issue, that is apparent on most other brands, is the nozzle can be overtightened and cause the 'o'-ring to squash meaning the centering can be off slightly and cause issues. If this does happen try using the larger BCN nozzle.
It is nice to use and doesn't clog too much and is easy to clean with a good supply of parts so no issues there. It is a nice good quality brush for the money and should give you hours of trouble free spraying.
Si
Thanks for the reply. And yes, I am back on the forum. Do you own this airbrush as well? I also bought an airbrush compressor with the gauge and all those stuff necessary for airbrushing. Additionally, I bought a spare needle due to warnings I have read on books and the net... I am still waiting for this to arrive from the US. Do I have to get a quick release adaptor as well?
Thanks, John
Originally posted by \Hi John, nice to see you back on the forum. Airbrushing eh? Nice one. I am still rather new to AB myself and have had to knock it on the head due to nowhere to do it at the moment.The Iwata Neo CN is a nice brush though, two cup sizes, although I would stick with the smaller one, easier to manage paint and you can top up if needed. One issue, that is apparent on most other brands, is the nozzle can be overtightened and cause the 'o'-ring to squash meaning the centering can be off slightly and cause issues. If this does happen try using the larger BCN nozzle.
Si
I don't own this brush, but I have used one-it is a friends of mine and I borrowed it for a while and found it a good quality item and noted the issues.
As for the quick release, they are a good idea, here are the reasons: You can run multiple airbrushes. If, for some reason, the trigger jams you can disconnect the air flow quickly. It prevents hose tangle when unscrewing the hose- no more unscrewing and winding the hose up. Also prevents thread wear on the airbrush coupling and hose.
Si
Yes I would add Si that I have found after completeing a session you can take the airbrush to the sink for a good clean.Comment
Yay! The neo for Iwata AB turned up yesterday. Great trigger action and nice box. Very nice AB which is new for $78 Australian dollars. I took the main components of it part and reassembled it apart from the nozzle and the air hose connection. Also the compressor, lube and spare needle turned up as well.
JohnComment
hi John, it should come with one , I sat and looked at my for over 3 mths before i try ed it did not have things right and it went sideways on me
and please listen to what the lads say as they got me sorted, with all there advice and help, and made things alot easy for me,second try today
and success ,have alook at my : posting need help with AB please : has alot off very useful info in it, that just mite help you as well and don't
make the mistakes i did hope this is off some help for you
moniComment
I got it for a bargain on ebay 78 Australian dollars including postage from the US. Great seller. He is still selling if you are interested. I have a link here to the airbrush since you are based in Australia like me
http://www.ebay.com.au/itm/NEO-for-Iwata-CN-0-35mm-Dual-Action-Gravity-Feed-Airbrush-/281285750307?pt=AU_Art_Supplies&hash=item417defee2 3&_uhb=1
this one is still a bargain, but slightly more expensive at $84
Originally posted by \cool nice to hear,John, bet you cannot wait to give it a bash,
,may ,i ask were you found that one please, as it a very good pries, was it in store or on line ?Comment
