Weathering a T72....."Jim's Way"
  • grumpa
    • Jan 2015
    • 6142
    Here's what's happened thus far, slapped her together somewhat except for tracks and kept top and bottom hulls separate.
    Prepped some "soft" stowage, left out big searchlight because I felt like it.
    Banged up the fenders and mud guards a bit.
    I use the cheapest acrylic water based craft paints.
    A mixture of 'pavement' and 'patio brick' colors are mixed 2/3 pavement to 1/3 brick and thinned with plain water.
    Thin it to a point where it will flow into creases and so forth, but also to where its not opaque but translucent.
    I apply it right over unpainted and untreated plastic, I usually apply three or four coats allowing each to dry first.
    Dry time is usually about 20 to 30 minutes under a warm light bulb.
    At time of pics she's had three coats of dark wash and one layering of forest green with a hint of leather.
    The method is "dry brushing"..... tedious I know :rolling:
    I'll give a brief description, I use women's eye shadow brushes, they are soft and durable and CHEAP!
    I put a miniscule amount of desired color on end of brush and dab most of that off on a paper towel, then on a piece of test plastic
    I check to see effect and adjust accordingly, one wants to put the least amount of paint on as possible per application.
    Technique, (mine anyway), is to very lightly, in a circular motion wisp brush along surfaces, you will see the effect.
    After a couple of dry brushed coats (again dry time 15 minutes or so) I go back to the dark wash, and pick out detailing, this process of dry brushing and pin washing
    is probably repeated a dozen times or so before it's all said and done (not counting extra detailing as with a diorama theme).
    I'll try to show perceptible stages to completion and hopefully provide an understandable narration.
    Thanks for looking in.
    Cheers!...Jim
    [ATTACH]308239[/ATTACH]
    [ATTACH]308231[/ATTACH][ATTACH]308232[/ATTACH][ATTACH]308233[/ATTACH][ATTACH]308234[/ATTACH][ATTACH]308235[/ATTACH][ATTACH]308236[/ATTACH][ATTACH]308237[/ATTACH][ATTACH]308238[/ATTACH]
    • 16165
    Hi Jim
    You make it sound so easy but I am sure it takes skill and experience to get results this good. Very interesting though. Shows that great results can be obtained with cheap materials. You and Ron think alike.
    • monica
      • Oct 2013
      • 15169
      real like how your done this one,Jim,and like me like using cheap paint were possible,real like
      the camo,netting ,and in some ways a like with the more,or harsher weathering,love it :smiling::thumb2:
      • grumpa
        • Jan 2015
        • 6142
        Originally posted by Jim R
        Hi Jim
        Thanks Jim, this is only the beginning though...she has a long way to go.
        Jim.
        • grumpa
          • Jan 2015
          • 6142
          Thanks Monica, she will be suitably "field worn" but not overly done.
          more to come.
          Jim:hugging-face:
          • PaulTRose
            • Jun 2013
            • 7096
            • Tattooine
            thats the key bit......knowing when to stop!
            often see stuff that has been over weathered......sure its a testament to the skill of the builder but its not realistic, in the real world AFVs simply arnt that worn out or rusty, but i like where you are going with this. i have some of that paint somewhere i got for a project last year, might have to hike it out and have a play
            Per Ardua
            • grumpa
              • Jan 2015
              • 6142
              Bit more done when time allows, made up some home made and scrap box stowage, it comes to me as I go along.
              Laying on several more washings especially where I want to create shadows.
              Pretty crude style I know, but that's just how I roll
              Thanks for looking in.....Jim.[ATTACH]309509[/ATTACH][ATTACH]309510[/ATTACH][ATTACH]309511[/ATTACH][ATTACH]309512[/ATTACH][ATTACH]309513[/ATTACH][ATTACH]309514[/ATTACH][ATTACH]309515[/ATTACH][ATTACH]309516[/ATTACH][ATTACH]309517[/ATTACH][ATTACH]309518[/ATTACH][ATTACH]309519[/ATTACH][ATTACH]309520[/ATTACH][ATTACH]309521[/ATTACH][ATTACH]309522[/ATTACH][ATTACH]309523[/ATTACH][ATTACH]309524[/ATTACH][ATTACH]309525[/ATTACH][ATTACH]309526[/ATTACH][ATTACH]309527[/ATTACH]
              • monica
                • Oct 2013
                • 15169
                like your style Jim,thank you for showing,:smiling::thumb2:
                • grumpa
                  • Jan 2015
                  • 6142
                  Thanks Monica, apparently your the only one.
