Andy's 1/72 Revell Topol
Thank you both.
There's a lot more work to be done but I'm happy with it as a starting point.
Thanks all 🙂
I've had the detail airbrush out today and have cleaned up the fuzzy edges of the camo as best I can. It doesn't look a lot different on photos though so I won't bore you all.
I've also sealed everything in with a light gloss varnish and I'll move on to washes etc once that's fully dry.
I've fitted the wheels now and given the model a matt coat. I won't do much weathering as I'm sure these would be kept in tip top condition, but a few finishing touches and it'll be done
HI Andy now i know this is a silly question but do the west know what the missle is like ? what resides in that big tube ? an should be a crackin build this
chrisb
It's an ss-25 ICBM (intercontinental ballistic missile) with a 1 tonne warhead, if my research is any good 😂
Normally the kit doesn't show the missile itself, just the launch tube, but since this is a missile & rocket GB I figured I ought to at least attempt to represent it
