Bronco 1/35 Schwerer Wehrmachtschlepper (SWS) armoured version halftrack
To ensure the small stretch of raised road conformed right to the edge the piece first required framing. I had purchased some oak veneer but test fitting it exposed an issue with the cut of the Styrofoam on one of the sides. I had used a foam cutter, and I had started from what I figured was a nice straight edge. Unfortunately, I didn't spot a couple of wavy undulations in it and adding the veneer would only expose the flaw. So, to plan B and I had just enough Basswood left from a previous project. These are 1.6mm thick. I marked, cut and added these four side pieces instead. I cut them a tad long so I could sand them square...or as sqaure as I managed to cut the Styrofoam! 😁
Click image for larger version  Name:	IMG_5849.jpg Views:	0 Size:	379.2 KB ID:	1236684 Click image for larger version  Name:	IMG_5850.jpg Views:	0 Size:	395.2 KB ID:	1236685 Click image for larger version  Name:	IMG_5841.jpg Views:	0 Size:	444.4 KB ID:	1236686
Once they had cured to the styrofoam with the aid of UHU Por glue, and each other, with wood glue, AK Asphalt was added in two thin layers, the cracks appeared all on their own, which was nice 😊 AK dark mud mixed with garden soil, tea leaves and scatter was added into any small gaps that were left around all the edges, and blended into the existing terrain.
The corners of the basswood framing were then sanded as square as possible ready for some matt black paint. A much-needed splash of colour was then added onto the raised embankment, care off static grass and MK35 wild grass. I’m not a fan of the slightly shiny grass colour out of the bag so once laid down with the grass applicator and fixed, these were airbrushed in different mixes of Tamiya Flat Green and Yellow Green.
Click image for larger version  Name:	20241011_223111.jpg Views:	0 Size:	608.2 KB ID:	1236691
Click image for larger version  Name:	20241011_223111.jpg Views:	0 Size:	608.2 KB ID:	1236691 Click image for larger version  Name:	20241011_223111.jpg Views:	0 Size:	608.2 KB ID:	1236691 Click image for larger version  Name:	20241011_223111.jpg Views:	0 Size:	608.2 KB ID:	1236691
I’m currently working on a small fence section utilising both cocktail sticks for the stakes and some broken and discarded Proton foam wire. A telegraph pole is also getting assembled to give the scene some height
I’m still in two minds about adding a small tree. It wasn’t in the original plan, and it might obscure the vehicle too much, but I’m willing to have a play around to see if it will add or distract from the overall look.
Its nearing the time when the vehicle needs permenantly fixing in place so I’m gathering together all the stowage and accessories to get them painted and weathered. I have been guilty of rushing this step in the past so I’m really going to try and focus on treating each one as an individual project. so I may be some time......
I'm also after a suitably small chain (not PE) for the rear tow pintle. Any recommendations on where to source the smallest size link chain available as the PE stuff is often too flat and unconvincing?
Here are a few
last few test fit snaps of it on the groundwork before the bodywork is fixed permanently to the chassis so I can get the stowage added.
Los,
the groundwork is stunning mate, as to the chain I make my own I twist the thinnest wire I have until i reach the tightness I require then gently flatten it with some pliers. IMHO it looks a lot better than etch chain.
