Last update today, finished painting, touching up few bits, etc.
Applied gloss and then applied transfers and even managed a half bodged attempt at a flag, with a bit of wind ripple too!
Left it for couple of hours. Then did a bit of what I thought was "light" weathering. But turned out to be heavy weathering. [Doh!]
Tried a bit of panel lining, but TBH, the deck is so dark, is did not really show up much?
The picture on the box shows a lighter grey deck, but the instructions show a much darker deck (mix of black and dark green), and I went with the darker look, maybe go lighter next time, ho hum.....
Then tried an all over general grime wash, which seemed to work ok.
Then tried having a go at chipping/wearing to the deck with a small cut off bit of sponge, loaded it with paint then wiped most of the paint off so when dabbed, only small traces were left on the deck, but I tried to put it in areas where there would be lots of foot traffic, wear, etc, ... But think I overdid this a bit!
Lesson for the day, = less is more.
Then tried some rust lines going from the deck, down onto the hull, where the ancillary equipment is located near the deck edges, eg: torpedo holding frames, etc. Think I may have overdone that a bit too.
Lastly did a very light rust wash to the anchor and few other bits, eg: rear exhausts/baffles and the propellers. Seemed ok.
But this weathering lark is hard trying to make it look realistic!
Finished for today, only thing left to do is apply a matt varnish, which I am hoping will "knock back" some of the excessive weathering from my heavy handedness.
We'll see, its all a learning process..... but generally happy with it overall.
Last pics for today...
