More of an impulse buy. Certainly not something I actually need.
I do like pistol grip airbrushes. I have one already as well as my H&S and an Iwata. So clearly I don't need it!!
The one I have already only has a 0.3 nozzle/needle.
This Gaahleri comes with 3 needle/nozzle combinations, two paint cups and even a tube of lub. Very well packed and quickly delivered. Cost was £108 with a 10% discount. At first look it seems well made and the trigger is smooth. Maybe a little bigger and heavier than the Mr Procon AB.
The big advantage of pistol grip airbrushes is the way the double action operates. Airbrush advice is Air on, Paint on, Paint off, Air off. On the 'normal' AB this means trigger down, trigger back, trigger forward, lift off trigger. This sequence minimises tip dry and paint splatter. With the pistol grip AB the sequence is automatic. The first movement turns on air and then pull back further for paint, release the trigger and paint is turned off before the air.
