HI Steven well i thought that when i started these planes id use a warm soldering iron with a pionted tip but no joy as i treid it on a bit of clear sprure an it curled up but your idea has merit will try again on them other planes cheers sirI think I saw someone cut fragile sprues like that with a heated knife, that way there's no presure on the vertical stabilizer, you melt it through as far to the right side as you can, then afterwards cut the last bit of the tail with a sprue-cutter. Goodluck, the planes are looking good![]()
HI Steven i'll see how things go today as ive learnt a lot more now ive listened to you guys advicePerhaps the soldering iron was a bit too hot? A dremel tool could also work, with a very small/thin grinding disk if you have that. Or some other very small grinding bit.
Not sure how big those wheels are Chris but if you have some round sprue or a cocktail stick, cut the cocktail stick back until you reach the diameter that you want for the wheel hub, then just dip the cocktail stick in some white paint and dab it on the wheel. That might work.AN i would have liked to have painted the white undercart an the centre hubs on the wheels but ive not got a brush small enough so they will have to stay black oh dear
chrisb
OH MANY THANKS for that info Joe i always get them mixed up an this is the dive bomber isnt it ?SBD is the Dauntless Chris. SBD stands for Scout Bomber Douglas.
HI Steve yes will take a pic of the plane near a humbroll paint tin an here a wild cat next to the paint pot an a dauntless now in the build stage in clear plasticWell done on the wheels Chris. Any chance of a photo of one of these aircraft next to a paint pot so I can get some idea of size. Cheers.
Cheers Chris They are small.HI Steve yes will take a pic of the plane near a humbroll paint tin an here a wild cat next to the paint pot an a dauntless now in the build stage in clear plastic
chrisbView attachment 1282631
YES they are Steve an bein clear plastic an tiny its a job to see where a problem is when they dont fit as im again finding on them dauntless planes an if i get the shakes then i pack up an have a cuppa but trouble is the prob is still there when i return OH BOY an ive just built two planes today an they are not compleate as still have to paint them an fit canopy an prop an a pic of the two i built today till my nervers got the better of me an lilley near had the model on the floor as she jumped up onto my table an near had the carrier off just as well i was there to catch it before it got smashed she is now banned from my model roomCheers Chris They are small.
