Ford fiesta mk 1 1980 van as a stl file
Ive been searching the internet for a ford fiesta mk1 1980 van stl file. Does anyone know where I can source one from. So a friend can print one out for me 1:50 scale if possible. as seen in the image below
Peter
it may be a mk2 but I thought it was a mk1 due to the filename but that may be wrong by the original poster of image.
Peter
I've looked on all of the sites I normally use and can't find anything, not even the car variant that would be a easy conversion.
That image has definitely been misnamed then as it's a Mk2. If it helps your search, the Mk1 has a bonnet front edge that goes straight across above the headlights, rather than dipping in between as in that image.
The indicators are also below the headlights, or in the bumper beneath them, rather than at the side as on the Mk2.
Foound this site https://cults3d.com/en/3d-model/var...zRcgeQCCS9ktxQ-BTvQTdON5VfMxZQeLxPHb2I5EkVQY2... I sent this to the lad thats going to print it for me.
Can some one explain to me how do you create an stl file of the van im looking for ?? Simply
Peter
I found that one but it looks like a mk3, so even newer.
If you have that one printed, simply paint the rear windows in body colour and you'll have the van version.
To create your own Mk1 van stl you'll either need to be very good with CAD, or try using one of the AI programs that can create a 3d file from an image, like Meshy.
