CHEERS Joe now a lot of touching up to do an paint the cockpit edges blackLooking good Chris, the paint has turned out nice and smooth
chrisb
Thank you Chris, you are a gentlemanHI Geoff that great if you do an yes you can an i get all my eletric stuff off ebay so if you want know anything just ask an i'll try an help you if i can sir
chrisb
YES Geoff any thing you want to know an if you do i'll write out a list of the thing you will need ok off ebayThank you Chris, you are a gentleman
Geoff.
HI Joe yes it was bloomin TAMYIA dint make the gun barrel trough deep enough so that the gunbarrels would sit in so i treid to just firstly cut off just one barrel but no no good the barrels just sat to high to get the gun cover to close down over them so then treid to cut off two barrelles an still no good so in the end had to cut off the gun 3 barrells an then usein twezzers fit the gun in an yes it then was ok i suppoce TAMYIA THOUGHT if the moddler wants the gun seen then the moddeler would leave the gun cover an glue it in open position well that not how i do thing if its possible to do what ive done then i WILL like the lights AN thinking TAMYIA did a better job on my big F14 SUPER TOMCAT as at leastGood work Chris, that gun installation looks tricky
THANKS Kaci yes this has so far been a very complex build an the instructions wernt that much help either had to sit an study them before i could move on to the next step as im looking forward to buildin my big uss enterpise in 1/350 scale an its another TAMYIA hope its easyier to build than this F16looking really good
