Hi there its the supermarine spitfire MK.VlllHi Pj, which version of the Spitfire is this?
Yes it is the 450 piecec of plasticthats a big kit
What type of paint is it?Can someone help what is the best thing to clean airfix paint
Yes it made it go stringy ill try ipa thank youHi Pj I got your direct message, but I will post my reply here so others can chip in with help.
As it is water based acrylic, you can soak it in Dettol, Isopropyl Alcohol or for stubborn paint in an ammonia-based cleaning liquid like window cleaner. Then simply scrub the paint off.
You mentioned that you used MLT, by that I take it you mean Mr Levelling Thinner? Surprised that didn't take more than the paint off. It isn't compatible with water based paints, hence your paint went stringy.
