Best wishes Jim, for a speedy recovery from the discomfort and ailments you are experiencing. We'll still be here when you are able to get back to your models.
ditto Jim from jen an i
chris an jen
+1
I echo the guys wishes.All the best to you fella.Im sure we will no doubt have added to the stash on your return.
Richa
Well,well.well! Guess what I just learned!That's a great haul, Jim. hope all goes well with your recovery.
Jim.Jim, that is all sounding complicated, hopefully you can find relief soon. Sounds like you will, but possibly over time. My best wishes for a quick resolution to your ailments.Well,well.well! Guess what I just learned!
The good news first, no hernia! great news indeed, doc thought he felt something
and to be cautious he ordered Ultra sound. Now getting CAT scan to see if there
is a strained abdominal muscle.
Now the maybe not so good news...maybe.
It seems there is a syndrome called "double crush" it is when the median nerve
is also pinched at the neck vertebrae, so carpel tunnel surgery does not relieve
numbness. After two weeks post first surgery numbness seems to be worse!
Second surgery on Monday, I am torn as to what to do, praying that is not the case.
From what research I can do on my own, the EMG test either does or doesn't show
if it is "DC"
But nerve doc said it was severe CTS with no other nerve damage.
I also found out after the fact that the median nerve in severe cases can take a very
long time to heal, up to a year in some extreme cases and that symptoms could
even seem worse for a time before improving. This is bitter sweet indeed! It seems
there is never a quick fix for me ever! If this DC is the case then only physical therapy
can begin to address neck issue and can work in degrees over time to near full-ish
recovery with much dedication.
Issue is whom will strangle whom first
View attachment 1296226 Jim.
Thank you so much my friend, your understanding of my situation is spot on.Good news regarding the hernia Jim but the other news must be terribly disappointing for you after going through surgery for the cts.
Easy for me to say but try to stay positive that at the moment it’s not confirmed and the nerve Dr is telling you there is no further nerve damage so hopefully it isn’t the double crush.
Only time will tell I suppose which is frustrating when you just want to be feeling better after going through surgery.
Hope you get more positive news soon Jim and you start feeling better
Geoff.
