Zvezda 1/72 Panther Ausf.D
flyjoe180
Joe
Joe
Earth
I have wanted to try a tank, having seen many of the excellent armoured vehicles being built. I did try one in 2015, which was my first try at an armoured vehicle, a Hasegawa 1/72 Tiger I. Here it is:
I have an Academy IL2 Stormovik kit which happened to come with a Panther Ausf.D (whatever that means). The Academy IL2 is theirs, but the tank is a Zvezda snap kit.
So thought I'd give it a go, to experience something different, and also to use my experience to see if I can achieve something a little better than the poor old Tiger.
The kit is a "snap kit", that is, they claim you don't need glue. The parts look nicely moulded, and a little bit of PE is provided for the things at the rear of the tank (engine intakes/cooling fans?). The plastic is shiny and feels greasy, so some cleaning will be required before paint.
Decals look good, printed on the same sheet as the IL2.
The options are seen below. I like the idea of Panzer Yellow, Green and Red Brown camouflage.
Made a start. Out of my comfort zone here, so I'm just following the instructions unless there is something that I know I can do earlier or later for ease of painting.
The suspension is very well thought out. Everything snaps into place as advertised; once fitted they can't be removed, so I have already learned that to read the instructions very carefully, as a dry fit turns rapidly into a permanent fit! I added cement to a few places just to make sure.
There is a third layer of wheels, which I will add once painted. The tracks look like they fold over the wheels and sprockets, clipping in to various lugs on both the first and final rows of wheels.
This Panther is quite small in 1/72. Each of the squares on my mat is 10 x 10mm. I imagined these tanks to be larger.
