Steve's Tamiya 1/48 Sea Harrier FRS1
HAWKERHUNTER
Halifax, West Yorks.
Well the winter period is not the best time for me to be building in my cold damp man shed but I will have a go. This is my offering for this Tamiya GB. The online reviews for this kit are that its a bit of a dog. This is one quote from a member of Brit Modeler "Personally, I wouldn’t touch it with a barge pole - brick-line vortex generators, poor intake shapes, inaccurate wheels and lots more issues". And just for a laugh its got raised panel lines.
Anyway Ill see what I can do with it. Here are the obligatory box and spru shots.
Thanks for following
Nice one Steve, I built this kit some years back, the build wasn’t that bad to be honest, filler will be needed. I think most of the problems are like you said the inaccuracies in the kit.
Good choice Steve. As Jim said, if we get bogged down in detail it becomes difficult to enjoy a build. One of the good aspects of this forum is that we don't have much in the way of intensive 'rivet counting'. Raised detail isn't a deal breaker either.
Look forward to seeing what you do with it.
Nice one Steve 👍
It gets some flak as it was one of Tamiya’s earlier kits. It will be interesting to see if it is as bad as some of its critics would have you believe.
Geoff.
Thats good to hear Tony.
Started work on the Pegasus engine.
The vectored thrust nozzles are very poor and will need some filling on the slats
And the ejector seat lacks alot of detail so will need to spruce it up a bit. There were a couple of ejector pin marks to sort out with some filler.
Thats it for now.
Crikey, you have some work cut out for you on those parts Steve.
Have you cemented the exhaust nozzles together? Looking at them, it may be easier to cut the vanes off, sand the halves, and join them with a smooth-facing surface. Then use plastic card to create new vanes, filling any gaps with acrylic putty. Alternatively you could try using thin styrene over the top of what's there to at least hide the visible seams.
And that ejection seat lacking detail, all I can say is it's an opportunity to enhance it.
Nice to see one of these in the GB. I've read all the reviews of it too - Tamiya's worst kit, total rubbish etc. etc. so I picked one up a few months ago just to see how bad it was... Actually I thought it looked ok - I cut all the main parts off the sprue and stuck them together with tape, and wow, it looked like a SHAR. I've not built it yet but I'm looking forward to it. I managed to find an old Airwaves PE set for it, and to be honest the only other thing I'll do to mine is cut out the aux intake flaps around the intakes and replace them with plastic card.
Looking forward to seeing the rest of your build.
I've read a lot about these early Tamiya Sea harriers. Looking at your thrust nozzels, I see it was all true. Good luck. We're all watching, from a distance.
Well chaps, I have been making some progress with this Harrier. First off the vectored thrust nozzles. I spent some time filling the gaps and smoothing these nozzles down but the end result was far from satisfactory. This is the best I could come up with.
As I began to get to know the model I realised that it had the potential to turn out a half decent build. That said I wasn't prepared to spend hours on the model only to slap on these junk vectored thrust nozzles. So an executive decision was made and they have been binned off and replaced with a set of Aires Nozzles.
The vectored thrust nozzles are a big part of the Harrier and the Pegasus engine and the quality and finish of these nozzles are streets ahead of the kit supplied ones.
Next onto the ejector seat.
The kit supplied one is very basic and lacks any detail.
So in an effort to add some detail I made some seat pads and head rest out of epoxy putty.
I then painted it up and added some seat harnesses made out of paper and ended up with this
The only decals that come with the kit for the instrument panel are for the front main panel only so I used some old redundant decals to add to the side instrument panels.
Next up was the Pegasus engine. This is now sprayed silver with the front cowling fitted. I am not bothering doing any work on the seam where the two halves join as this wont be seen. I intend to display the model with the top access hatch open so the top of the engine can be seen. Engine seems a nice fit in the fuzz as do the two main air intake cowlings. Only thing I will do with the engine is splash a dark wash on it to oil it up a bit.
Finally a dry fit of the fuzz halves seems to indicate that there shouldn't be too many problems there. The seam clean up will have to be done with care as the model has raised panel lines and repairing these is not something I have attempted in the past. Any advise would be welcome on reinstating these raised panel lines.
Thats it for now. Thanks for checking in.
It was well worth the extra cost to replace those nozzles - I think I may well do the same with mine when I build it - like you said, it's an important part of the Aircraft and it needs to look right. You also did a great job in up-detailing that seat, it looks much better.
Looking forward to seeing more progress - it actually makes me want to pull mine out of the stash.
