Zvezda 1/72 Panther Ausf.D
That is looking great. Seems odd to have PE included in a "snap together" kit. The track gap hidden under the side skirts is probably a common cure for a common problem. That's a fine freehand camo.
Thanks Jim. I feel better about the track gaps now, thought I might have cocked something up. The Panther comes in a combo with a Stormovik. The PE was stamped "Academy", so the PE probably is not normally issued by Zvezda.
Nice paintwork!
1/72 model parts for AFVs are so small (got one underway currently, too).
That airbrushing is exceptional.
You can stitch track ends together with a needle and thread to connect them.
Thanks David, appreciate your comments and the track solution. I never thought of stitching them, that's a neat if I do ever another tracked vehicle.
In the days of building tanks, I did that and then pushed them onto the wheels post-painting. A tad fraught, but the assemblage was pretty strong.
Painting and dry-brushing the wheels just became too much of a chore in the end.
I have now painted and fitted the various accessories. A quick gloss varnish followed by a dark brown wash, which has also acted as a filter and toned down the scheme a little. I will dirty up the rear section and apply some dust after the decals are applied. I'm happy with this little kit, a most enjoyable build.
