I.D.F M113 Fitter
Isitme
Having built a fitters vehicle some time ago, I had at the time obtained another kit of a different variant. This has sat in the store for all this time alongside the Zelda.
After getting the Chieftain ARV underway I needed something to fill in during the periods when that build grew a bit stagnant.
So out came several kits from AFV's to aircraft, and back they went, and out they came again, and again untill I finally settled on the old Academy I.D.F. M113 fitters vehicle.
First order of the day was to get out the research and this is well covered in the Desert Eagle Publishing book by Michael Mass & Adam O'Brien #9 Part 1 - Fitters.
And also Eduard came into the job with a couple of etch sets plus there is going to be some scratchbuilding.
After looking at the kit I decided to replace the floor with etch, first the moulded tread was removed, the sides sanded the interior sanded along with locating points being removed and yes - sanded.
To make the job easier I decided that the interior was going to be built/scratch and this means the hull top will be left off, and that I would work from rear to front, this also means I can work on the hull top without damage.
Number one on the build was the fuel tank. I rubbed down all the moulded detail, had a look at a couple of walk around web sites and gathered the information I needed for the tank/pipes and fittings. These were all made from rod, pewter sheet, copper wire and odds and sods.
As you can see there is still some pipe work still to be completed (the floor is removeable) before moving onto the tool box and ammunition box storage on the right side.
More later,
Mike.
The detail work on the box is fantastic. I really don’t think that could be bettered.
Very nice indeed Mike, the Scottie ( Paul ) will like this he was in the REME and may have been in them. Looks really good.
Update,
Before I go back to the Chieftain ARV I thought I would show how far along this one has gone.
The fuel pipes and pump are now complete.
A bit blurred but you can get the idea. The floor is now in place as well.
Then I moved onto the other side and built up the ammo box racks from pewter sheet along with the retaining straps.
The small stowage box underneath was from plasticard and pewter sheet with scratch hinge and on the other side the fastener.
Next it is the large tool box with sliding doors and inside can be seen the tool drawers.
And that is it for today, more after I have caught up with the ARV.
Mike.
Hi Mike
Your scratch building is always so neat and intricate. Inspiring stuff.
The pipework is amazing, all the detail going into this build is so impressive Mike, cracking work.
Scottie,
Jim R,
Graeme C,
John Race,
Neil Merryweather
Many thanks for your comments, they are well received.
Mike.
Update,
Been a bit of a slow week or two, had the first of my jabs on Monday, ended up with a reaction to it and that knocked me off my stride for the week. But pleased to say the second head is now growing well under the UV light.....
So where were we ? The cupboard/tool box is complete and if we look to the other side we come to the hydraulic tank and pipes for the HIAB. The kit offering is pretty basic if you are showing a couple of hatches open...
But as I had decided to rebuild/kit out the interior I went with this...
Now with the roof removed....
The front view...
Not too happy with the tiedowns on top of the tank, and there is still more pipe work and electrical work to install. As you can see I had to add to the width of the tank and the item in front of it to match the photos of the original vehicle. The front bulkhead is in place again with a strip on top to make up the shortfall where the original roof (infantry) had a bar running the width of the vehicle (model). There are two oil filters now in place, with one just visible behind the post for the HIAB and the other behind the drivers seat post. A new plate had to be made for the pipe connection box (white block).
And apart for a tidy up of the workbench....
That is it for this update - more next week...
Mike.
Hi Mike
I had my jab last week. My arm ached a little for just a day.
As always I'm very impressed with your scratch work. It is always so clean, neat and looks the part.
Hi Mike
Cheers Jim, only looks clean after the clean up...
I am allergic to Penicilin, so that may have been the problem, none of the reccomended reactions. In bed Monday night, I violently shook for about five hours, could not even hold the paper to read about the symptoms. Mind you she had hers, and the new lining on her tongue looks fantastic, even got racing stripes so she can talk faster......
Mike
Mike
Yes, but how's your 5G reception, and has Bill Gates been in touch yet? :smiling5: :smiling:
Update,
Been a while since I last posted, so nothing missed....
The pipework, various parts, rifle rack for the driver, electrical wiring etc now inside the hull and primed...
The wiring that goes across the fron inside has been replicated, and the steering levers rebuilt....
The drivers compartment engine bay side wall is also complete....
Bit blurred but will do pics once painted.
All that is left of the inside is to complete the roof inside details, ramp actuating rods, wiring for the coms and lamps etc.
Again sorry for the blurred images, will do better next time.
Mike.
