- Joined
- Apr 27, 2018
- Messages
- 15,228
Hi all,
I had a look through my stash of two kits lol, and decided on this one. It's the HobbyBoss Leopard Bergpanzer Buffalo. I don't normally do modern armour, but this was a Christmas present from my daughter and her partner.
It comes in a big box and I wont bore you with lots of sprue shots. That said the box contains 14 sprues moulded in a buff plastic the detail looks good and no flash to be seen. As well as the main sprues the hull comes in two halves upper and lower as you would expect. Also in the box 1 set of vinyl tracks, 1 sprue of polly caps for the wheels, I set of decals to portray a German or Canadian version. 2 small sheets of etch, 1 small sprue containing spare track links and finally 1clear sprue containing lenses and vision blocks etc.
The kit comes with a full interior of which virtually nothing will be seen. The kit comes with additional armour which cover the side access hatches so even less can be seen. The intention is to build this out of the box with maybe a few tweaks along the way.
cheers
Scottie
cheers
Scottie
