I would think it can cut poly sheet. It is a scalpel blade and if you use a ruler and a scalpel, cutting poly sheet is possible. All it would mean is taking a few passes at it.\ said:Can it cut polystyrene sheet? Up to what thickness? I think it could, up to 1 mm thickness but thicker might be a problem, poly being quite hard. By the way, when cutting thick poly sheet, I use my Tamiya scriber. It cuts a groove in thicker sheet against a ruler (well held or clamped) which can be deepened with successive passes
Tasty bit of heavy metal Tom\ said:
How many kits John!?
More Airfix Mustangs I see![]()
Told you when I saw you earlier you had a good selection mate, everytime I go to that car boot its just tat with not a kit in site![]()
One can never have enough MustangsPatrick
