Revell STAR TREK VOYAGER
Looking great mate... cant wait to see it done. I'm hoping to get back to Sarah's one soon... having a baby and busy with work has slowed everything right down!
video on progress voyager to add to pictures , shortly I begin on spray thanks for all positive comments help issues have held me back but it will be done
A pre test of base board and help , on attaching ship to pole ,1/4 wide no thread ? , wires top of pole go into ship need to attach top pole then into ship
Many thanks , blown bulbs nacelles navigation have stripped back to thrusters resholded , personally getting me down .as enterprise bulbs blown sent back for repar so all work on both now back two months patience well thats gone cry View attachment 254002
voyager  progress  plus head ache
                                                        attaching  model to pole , now cost me  bottom  belly section  luckily  back up kit  so window being drilled  out  those sitting in  wings  watching  I hope you don't have as much despair  frustration as I have  , there is an  answer  some say give  up !!  nope to much £ input  I wont give it  the satisfaction  hence nearly bald .
              moan  aside  ,
                                     (it's  illogical  Jim , its a model  the needs of the one out  way  ,or  view   of the     doubters  , even  you're  self  emotion  is human  fault  surpress  coz  the strength of the mind will   survive .  )   :S >:( O.o   yep  all those  feelings arrrrrrrrrrrrrrr
                                                    progress away from  the other  upper  hull  , fibre  optics being  feed though windows last count 20 , ?  about same to do  blue , painting  upper hull next few days catch  up bottom pole  arr rr  , delta flyer on table being  rubbed down  under coat   o that is small   mag  even  struggling  luckily only me needs a cuppa ha-ha
Tell me, are you using a combination of LED's, optic fibre and incandecent bults or just LED's + optic fibre? Just how many are you using, are you making up your own loom or are you using sets? how big is your power supply?
As you may have figured out, I'm looking to use this, but on a 1/24 truck trailer kit with an internal workshop.
I'm trying to gen up on the process and components.
Any guidance will be appreciated.
Keep on trekking!
Gavin
Hello snow man
     This an on going try and error ,LEDs s strips just wasn't bright enough so I bought bulbs both blue white and fiber optic strans which I have put a rubber tube on end of bulb and put strans , into tapering off to hold within  model there is room inside , all running at 9volt battery soon electric ,
The battery's soon run down
The base stand has been custom built with power supply added all fiber optics range on eBay £2.98 with poastal all sizes down to the smallest buy these are small heated at the end the expand to fit into windows .i hope this helps more work in next few days enterprise as well cryton
imageproxy.php
imageproxy.php
imageproxy.php
imageproxy.php
Voyager on going fiber optics trimmed melted into windows expanded , more strans
 On route
Painting of rear test before  decals,added shuttle bay .thank you all for positive feed. Back cry
