superb looking beastly,real like the weathering,and the mud,over all,just the grimy look,
very well done,and the base blends in,like the idea with the reddish shade of dirt as well,
great build this one,![]()
Thanks for the kind words Dave.
You are correct about the tracks.
When I built the lengths I found them to be just a tad too long.
After quite a bit of thinking and test fitting this is what I came up with.
I glued the track(I alway's put tracks on prior to painting)to the return roller,when set I then glued the track under tension to the front roller,again when set, I glued the track to the rear roller.
The next thing I did was to glue the bottom of the track to the wheels,for this I coated them with Testor's cement and when about half way dry I
pressed the tracks together as tight as I could going from the back to the front.
There was a bit where the track didn't quit sit correct at the front but this would be hidden by the blade support's and covered with dirt.
I hope this helps.
Ralph.
Grimy dirty not to over the top just perfect lovley build
Wow, great work and very realistically done!!! Well done Ralph.
That is just a stunning peice of workmanship,the weathering is spot on the whole thing looks so realistic.
fantastic job
Top work Ralph. Very, very nice.
