Dragon 1/35 Sd.Kfz. 234/3 #6786
Very nicely done Patrick. To late to open the hatches...?
Thanks Ian, unfortunately only the vision hatches can be opened & they don't allow much of a view. I'd hoped that the front hatch could be opened, but although Dragon provide a hinge, it isn't actually workable :(
Very nicely done Patrick. You could always add an LED !!!
Great weathering and chipping work Patrick, even though much of it wont be shown, we can see it now, and it limbers you up nicely to do the exterior now!
I did consider the LED idea from your build, but as it's an open-top I thought too much light would come out. Maybe I'll do it on a cutaway project I've got planned for next year ;)
Thanks John, the exterior is causing me all sorts of headaches! The fenders don't fit so I've had to break out the G-clamps & the stowage bins are all photo etch :(
Ouch! Clamps may well distort other surfaces, what a pain. I struggle to comprehend how this happens in the context of a highly engineered kit, other than occasionally a rogue sprue slips through the net. Oh well, I'm sure you'll sort it - folks around here usually do! Good luck!
just caught up with this build Patrick , love the internal weathering , pity about the fit issues , from what I have seen of your build's , I'm more than sure you are up to the challenge
Thanks Steve
Although the end of the GB has come & gone, I'm still working on this one.
What's been holding me up is the doors to the equipment lockers. Dragon provide very detailed brass doors, but no styrene alternative. The problem is that the latch & padlock detail are tiny! A neurosurgeon would struggle with these parts. Here's an example
View attachment 273026 View attachment 273027
But I soldiered on & ended up here
View attachment 273028 View attachment 273029 View attachment 273030 View attachment 273031
That's the vast majority of hull parts added. There's a few sticky-out bits left, but I'll do them later so I don't knock them off while painting.
Thanks for looking
Patrick
real dose look good, Patrick,do like the PE,always gives that bit more,;)
Thanks Moni, I've got the camo painted now - from what you've said in other posts, I think you'll like it ;)
your were right Patrick,love it,great job with that,well done,:D
Thanks Moni, I remember you said that you liked the red-brown over yellow scheme... I think it was on a Panzer IV.
It's not often I go off track with German camo, nor is it that usual for me to use acrylics! ;)
