Hello all!
This is the thread I am using for the diorama base of my Land Rover thread:
http://www.scale-models.co.uk/threads/1-35-revell-series-3-landy-farmtastic.25932/
I'll be moving most of the work here as it's all going to be diorama based now, I'll probably not update the car thread.
What I've got so far, is a rough idea, some MDF and some plywood, and some small hills made out of that. Baseboard is 250mm X 300mm
These aren't biscuits in this following image, they're old coasters. I really am just cobbling it together to make a basic base up. The white panel is foamboard as there'll be a puddle there and I'll need to dig abit.
So here I've put another bit of ply on top and chaindrilled around where the puddle will be. The white foamy stuff further back is packaging foam that I've used to pad out some of the sharper edges.
Then naturally I've just papier mache'd the whole lot, with some kitchen roll on top to soften things out. This is not the final layer and there will be a bit of mod rock plaster of paris stuff on top in places.
Photo artificially altered to try and show it, the white was really washed out.
Thanks for looking
-Matt-
Thanks for looking
-Matt-
