How to create a blacked out window
Thinking about it
Staff member
Admin
Website
www.scalemodelshop.co.uk
Halifax
I want to create a blacked out window in a van, what's best to use to create the effect?
Hi John.
Black paint would work:p:D.
Seriously,you could use a couple of coats of Tamiya smoke(from the inside would be best)
and finally add a mist coat of a very dark brown.try it on a piece of clear plastic;
Hope this helps.
Thanks Ralph, I didn't think of Tamiya smoke, you've also made me think about Ammo, they do a crystal range which I've just been using for the lights, I'm sure they have a dark one, I thought maybe there would be a different way of doing it.
Tamiya ps 31 spray built up in layers might work
For the size of the piece I think I will try the Ammo crystal smoke, and I don't stock PS sprays, only TS & AS.
I've just had a bit of an accident, I was using the Ammo crystal orange, I shook it up but it didn't come out too well, I squeezed the bottle a bit harder and the top came flying off, paint everywhere, it looks like it was the ball bearing that was blocking it.
Have you got an airbrush John? Perhaps a thinned down black paint may help in layers. Saves you spending money and time? :)
They certainly look promising! Incidentally I've just picked up some Tamiya clear colours today for lights and such.
I did wonder if you could mix up a tinted varnish?
I have some Humbrol Matt Cote, and I wonder if a few drops of that, with a tiny bit of pigment from either normal colours, powders or whatever with a small drop of water could give the same translucent effect? I may have to try this.
Been there and done that not so long ago John not funny at the time unless it isn't you it happens to.:D
I use the Tamiya smoke spray quite a bit. It goes on nice and evenly and with enough coats will do exactly what you want.
I used the Ammo smoke, it worked well, I wanted the side and back windows quite dark, and the front with just a tint, I probably went a bit darker on the front than I wanted.
Nice to see you posting a build John. Will we get to see more of this?
