Steves zsu-57-2
Building them in steps together, so will see how it goes, takom definitely an easier build than the shilka-
5 part wheels, sanded down the very prominent rib details about an hours work !
Nice choice Steve, also looking forward to following this build ;)
very nice Steve,dose look interesting,will be sitting in on this one,;)
nice start with the wheel,s ,I think I,would paint the rubber,first,them put together,
but that's just me,:confused::rolleyes:
very nice steve , those instructions look better than the norm too mate .
I did think that, but a very thin part of the wheel rim is on the tyre part, so would still need masking just for about 1mm, may as well mask the whole lot together, if i even do. These days if i get some paint into the hub , upto the edge, i am happy as weathering 'destroys' the neat line. :-)
Drive Sprockets
Detail is sharp, big problem is when you join both halves together, there is a locating plug, which is to long for the notch so needs sanding back and when you do join both sides together, there is that much play its silly, so you have to line up things by eye and then I made sure the teeth lined up by placing upright on the table and ensuring two teeth on each side touched the desk
Idlers
Same issue as with the drive sprockets
Multi part mount
Looks really good made from 3 pieces (separate brake ?). easier to build the unit on the tank to make sure all the bits line up together.
All that is missing is the 1/48 A-6 Intruder streaking over head!!:p
Nice choice of interesting mobile AAA.:)
Now theirs an idea, maybe a 1/144 Intruder or Phantom placed in the rear of a dio so at 'viewing' height looks right - loosing of a missile/ bomb, hmmmmm
