What a bugger of a day
OK, I know I am not firing on all cylinders due to a really heavy bronchial cough and not breathing or sleeping well but I am really struggling with the Bizzy.
This simple conversion of the funnel top took me over two hours. Cutting the plastic away was bad enough but the PE parts would just not stick using superglue even using spray accelerator, the bits just kept falling apart.
So, it has gone from this
To this
Next up was a short length of railings that need to go round the edge of a sticky out deck piece (I know all the nautical terms) that then slots into the main funnel piece, I assume it is the access deck to the two large searchlights on either side of the funnel. Got it roughly curved to shape, attached one end with a drop of superglue and took dog for a walk to give this anchor point plenty of time to harden. Came back and, after a cup of tea, picked up the part to anchor the next bend ( the idea is to anchor at specific points with superglue then run a bead of thin PVA to seal it). However, as soon as I picked it up, the railings part just fell off, not stuck at all. The PE has been cleaned with alcohol but it still doesn't stick.
Started again, this time using accelerator again, and finally got a single point stuck. Moved to the next point, added superglue held railings in place, sprayed accelerator and held for a few seconds more. Released my grip only to find railings stuck perfectly to my finger but not even touching the plastic. In separating the railing section from my finger, very gently, the railings broke at the 45° bend.
I said two very, very rude words, switched off the desk lamp and just walked away. Really, really peed off now. I have decided that I am definitely losing dexterity in my fingers and that this will be my last major PE project. Definitely will not be using all of it as I have said before but I will be using a lot less than I hoped I would.
