Trumpeter KV "Big Turret"
Mr Bowcat
SMF Supporter
London
I found out today that there is a model shop near where I work, so I popped in on the way home. It seemed rude to leave without buying something so I picked this kit up for the bargain price of £17. :)
Apparently it had been reduced because of the box damage, but the contents are fine.
Be prepared for a less than enjoyable time with that kit Bob. I've built it & the one I had was covered in ejection pin marks. I'd also recommend a replacement barrel from RB Models.
great bargain,Bob,I have built a couple of these,s ,and unlike Patrick,did not get
the ejection pin marks,maybe there was a bad run of them at some stage,:rolleyes:
you should enjoy this one,:D
After the part heavy Meng King Tiger I fancied a low part, easy build before I tackle the Meng Bradley. :)
So far so good, got the hull built. There was a lot of flash and/or seams on almost every part. The suspension arms alone took almost 30 mi utes to clean up. :(
Not what I would expect from a Trumpeter kit. I have yet to build one, but have bought about ten, and I havn't noticed any flash to speak of on those. Is it likely this was merely a bad batch, or is flash and mold lines to be expected on Trumpeter's kits?
To be honest it's the first trumpeter kit I've bought, so not too sure. I think it dates back to 2005 so maybe they have improved a lot since then?? It's certainly a far cry from the kit I just finished (Meng) but the that's a lot newer.
Told you! ;) wait till you get to the turret! The mantlet is a nasty piece of work :(
With regard to Monica's post, I'm fairly sure she built the other Trumpeter KV 2 kit which isn't so bad.
Keep going though Bob!
Will do. If nothing else it will help me learn to pay attention to detail on every part, something I haven't always done on other builds.
Plus it's Russian and WW2 so I can practice getting it rusty. :D
Trumpeter are a company of extremes! Some kits are excellent & rival the best of Tamiya. Their T-62, E series of German tanks are all excellent from my personal experience.
But then their flagship kits, like the 1/16 King Tiger is an injection pin nightmare! Many parts are inaccurate & poorly fitting. Not what you'd expect after paying over £200!
Always best to check prior to purchase or be ready for a challenge ;)
Sad to hear. As mentioned, I've yet to start building one, but the following kits I've bought and looked through, and really enjoyed what seemed like virtually flash free sprues:
02312
02324
01563
01587
00374
01514
01523
01524
All 1:35, spanning the years 2008 - 2013. So maybe this is a case of newer kits having less problems with this, unlike Dragon (and possibly Tamiya?) which does not seem to have had those problems for close to 20 years.
Yep, something along those lines.
Out of interest (if you remember) the part that sits to the side of the drivers periscope is shown in the instructions as sitting in a little slot. However there isn't a slot on the kit. Did you just glue it in the right position or did yours have the slot?
View attachment 281023View attachment 281024
I don't think mine had the slot, so I trimmed the part & just glued it in place.
