My second session with the
MRP paints and they did not disappoint. In this session I had 8 colour changes over about 50 miniutes spraying. If this was Vallejo I would have had to stop at least once probably two or three times to clean the airbrush to prevent tip drying. I did not have to stop once and suffered no tip drying at all. All I did was spray a cup or two or i.p.a. between colours. At the end of the session I did a strip clean and once again found the inside of the airbrush a lot cleaner than I would have with the Vallejo. I am using a lot less cotton buds than previously!!!
To be fair only 6 of the colour used were MRP, the other two were AKI metallisers, dark aluminium and titanium. These AKI metalisers share a lot of the same properties as the MRP paint. Given that MRP metalisers are also getting good reviews I will consider swapping to them once my supply of AKI have run out or depleted.
We all know how yellow can be problematical. I found previously that using a yellowish primer improved coverage and the amount of paint and coats used. MRP is no exception. I first sprayed the MRP Sand Yellow primer and then the MRP RAF Marking Yellow. The result, as you can see, is a flawless finish. I will be masking off the tips of the prop tonight to spray the rest black. I sprayed the spinner base yellow simply to ensure that I had a consistency of red across the spinner. The trick tonight will be to mask the yellow band ready to spray red. That is always trickey but I have a method that has worked before and I will post that in some detail.
Inside the wheel wells, sprayed interior green plus the tail wheel strut. Some more masking and detail painting to do there tonight.
MRP Tyre Rubber on the tyre wheel looks a good tyre colour to me. I clearly put the mirror in the wrong batch and painted that with the black primer.... not an issue as it saved me from doing it later when I black base the airframe. The wheel legs were painted AKI Dark Aluminium to a beautiful even finish.
A few more parts above. The inside of the wheel well doors are painted AKI Titanium and when I took this shot one was still a bit wet. I overdid it a bit on that one but, fortunately, when I looked later the finish was fine, like MRP the AKI metaliser was very forgiving. This was at the end of the session and I was a bit over-confident!!!
AKI Dark Aluminium again....
These I painted with the GMP silver primer simply because I expected to show up some corrective work to be needed on the seams and wanted to check out its appearance. I was not wrong! I will be treating the seams when I get a chance. I also rather like the colour for these drop tanks that I believe were not actually metal but were painted silver. I think I will repaint with the primer and leave it that colour, apart perhaps from what I believe to be metal bands which I will paint another metaliser shade.
that is it for last night.
Once I have painted the detail I will be glossing and weathering these parts.
