If I'm going to do the airbrush upgrade I will need a new compressor.
My "local" hobby store that I buy almost all of my stuff from has these two in store right now, and a Panzag compressor that I know nothing about.
The Sparmax AC-27 Achieve is the cheapest, obviously, at ~£160, TC-610H costs ~£280 and Panzag ~£220
(the prices are not exactly these ones, but for comparison. I'm using £1 = 10 SEK for exchange rate to make it easier for you)
The AC-27 has a max pressure of 50 PSI and airflow 13-16 lpm
http://www.sparmaxair.com/product_detail.php?id=1&r=3
The TC-610H has a max pressure of 60 PSI and airflow 23-28 lpm
http://www.sparmaxair.com/product_detail.php?id=1&r=7
Panzag has a max pressure of 57 PSI and airflow 20-23 lpm
https://cdn.starwebserver.se/shops/hobbyland/files/438930.pdf
Today I've got the cheapest of the cheapest compressors, or "compressor" to be honest... It's a plastic 10 PSI membrane pump to be honest. Not very good with acrylics like Vallejo and AMMO but works well with Tamiya.
I've spent more money than I could afford really on kits, paints and tools so I'm going to spend money I actually can't afford to be honest on a new compressor and airbrush, so I don't want to spend more money than I have to - but at the same time I don't want to buy something crap that I'm going to have to replace soon anyway...
The AC-27 is a "beginners" compressor but well within range of what I think is needed for scale modelling, but I don't know how good it is. It hasn't got a tank as far as I know and thus has to be "always on". This I can live with.
The TC-610H has a tank and will thus have a more consistent airflow, but will I really notice this on 15-20 PSI?
It's almost twice the price.
The Panzag also has a tank, bigger than the TC-610H but not by much. Also more expensive.
I'm going to buy an H&S Infinity CRplus Two in One airbrush so that's £240 on top of the compressor, plus I will also need a moisture trap but those only costs around £17-ish.
I've got a dual tank 10 bar compressor in the workshop that is adjustable, but I don't know how low I can set it - and it's a lot louder than any of these!!! I already own it so that is one benefit - but it's very heavy, albeit on wheels, but dragging it out to the workshop whenever I need to use the compressor there isn't wishful either.
What should I do? Is the AC-27 good enough or is the lack of a tank noticeable and I'm going to have to buy another compressor yet again next year?
If my cheapo plastic compressor didn't overheat I'd continue to limp on because it sort of works with my Ultra airbrush, but I'd like to progress in the painting department and I think I've reached the limit with my equipment.
Appreciate your input here
Cheers!
Cheers!
