Scratch built 1/32 SS Wilton Castle
Hi all well since my kit building seems to be getting very shabby i thought maybe going back to scratch building may get them back on track I had a choice of plans to pick from and I narrowed it down to 3 possible
I eliminated the St Louis Belle as I want a fairly quick build not a three yr jobbie also I eliminated the Kitty as it was a little too simple so I opted for the WC
Normally I like to build large scratch builds but due to space I'm reducing this by 50%
First problem is that the keel at the reduced size is very flimsy so I've changed the plan a bit to give some strength.
Hi all I don't know if anyone has any better methods but this is how I did the rings for the paddle wheels on the Pamela 3
Keep the centre bit to help with centering the spokes
Hi all this is designed for electric motor rc but since I'm doing it as a display model I thought I would have a go at making an engine for it (Not a working one I hasten to add)
I decided to try and build this for it
Obviously it has to fit in the ship so I've just made it a gazillion times harder as I have to make it a lot smaller to fit in the ship. I thought I would try one of the simpler things to start with, this bit.
Looking Good,
For cutting rings, for another purpose, i built a simple jig for my router from MDF.
Painted the inside with pva glue to help stiffen it all up before adding filler.
Can anyone guess what this bit will become
Hi all here's the next update done some more to the boiler
Loads more to do to this bit but quite pleased how it's going.
Hi all well it's starting to look more like a ship, needs some more filling but definitely getting there.
Someone suggested an upright boiler and seeing as how there is no room for stoking the boiler with it in place.
I've decided to have a go at doing an upright boiler, I mean the chimney is not even on this boiler yet so if I added that there would be even less room.
