Mark IV female from Takom
Neo
Greeting! I would like to show you my latest project. This is Mark IV #2009 from Takom. I am fond of building British armor, especially cruiser tanks. So this Mark is something new for me. Dozens of bolts and rivets. I build this kit with help of great master - Andrey Fonin. He is building another Mark.IV, but his variant is a destroyed tank.
I ahve a little progress so far with front hull. Hatches are movable and now they have correct thickness. Chain are handmade. Pistol ports covers movable. I have replaced all bolts on sides. Takom's variant of the bolts look like rivets.
Neo glad to see you here and really glad you brought this with you.
Scottie
Hi Neo and welcome, I'm glad you made it here, how I/we can see how it turns out (I can see where I went wrong) :smiling4:.
Pete.
Pete.
Hello, Pete! Thank you for the warm welcome! I will try to avoid mistakes. And unfortunately I do a lot of extra work that not could be done.
Hi Neo
Great work as usual. I now want to see you scratch a fully working engine for it. :smirk:
Regards Lee
Neo
Massive fan of your work. Looking forward to seeing this one through to completion
Excellent work Neo as usual. I see you removed the rivet underneath the lewis gun :smiling4:
Hi Neo
Regards Lee
Hello,Lee! I think engine will be very hard to build,because I wll need authentic fuel and oil for it:tears-of-joy:
Neo
Hello,Steve! thank you, I am pleased! Unfortunatelly works with sides of the hull takes much more time that I have expected:sad:
Greetings! I have found that Takom gives wrong location of the towing device from the inner side. Don't trust Takom
Than I've tried to make another chain with fixator. Now I am working with inner part of the hull side.
Progress is very low. Only idler tensioners.
(Photo for discussion only)
Nice move sir, it's a good thing to always check and dubbelcheck your references.
Yes, I always use 2-3 walkarounds. So I don't rely on manufacturers variants for a long time:relieved:
hello Neo,
Great to see your build has made it across, it would have been a shame to miss the build.
Cheers, MikeC.
hello Neo,
Cheers, MikeC.
Hello, Mike! I will try to make something special to hold your attention :smiling:
