Hi this is No2 one on the Pete's Toon production line the Russian KV-2. One for JR.
It just to hot to paint at the min, so building these little bad boys.
Parts.
The turret, I've done some very small upgrades.
Lower hull /all the wheels have poly caps so on/off for painting.
Added over size nut/bolts to tow shackles front & rear.
Made missing lower support brackets & rivets to mudguard.
Fitted upper hull fittings, made front M/G from brass tubing and copper wire for the radio mast.
Building stage completed.
The two I have built so far.
Thank you for looking in.
Pete.
Parts.
Pete.
