CHOSIN FEW at Funchilin pass
well John and Paul i tried to remove it but unfortunately l glued all the rope.... BUT... since i'll do these 2 trucks (one with winch and one without)...in both cases there is so much stuff in the front you won't see anything...
View attachment 307912View attachment 307913
Hi Greg
Good to see the trucks started.
this truck is reallly more "complicated" than the other one... but still loads of fun :smiling5::smiling5::smiling5::smiling5::smiling5:
Hi Greg,
See I told you it would be fun.....
Just caught up to you on the build and the cab change over, some good work there to get the shape of the entry into the cab.
Will look in later to see how the build is going. I take it you have superglued the winch cable in place. Can I suggest taking four or five long strands of copper wire from electrical cable, put one end into a hand drill and hold the free end with pliers and twist untill you have a length of cable. Then run it over a candle to soften it, after that cut the loose end from the cable already on and wind the new one over and across it to form the new cable.
Hope this helps, Cheers, Mike.
Great start on the cab. Is that a dry fit of the bed fold down seats? I believe they were mounted higher up, or is that one of the adjustments you mentioned? Just an observation. PaulE
Thanks for your suggestions Paul and Mike i changed the cable... but i dis not understand you comment on the “bed fold down seats”.... :smiling::smiling:View attachment 308276
The photo at the top of this page shows the fold down seats in the bed folded in the up position, thus the sideboards look complete. The photo of the model's bed shows the seats folded up, but too low relative to the side boards. I was hoping to help out by bringing this to your attention. I believe the seats were attached to the sideboards, not the bed, so when sideboards are removed like in the second photo, the seats go with them. The winch cable is much improved, once painted, the fix will be invisible. PaulE
thanks John for your encouragement... and Paul THANK YOU very much... l really didn't see the mistake l made... l had a MASSIVE BLOND moment... thank you again for help and your very kind comments
Outstanding chain work. The 105 apparently was just a warmup. PaulE
Thanks Scottie and Paul well i still have to do another truck 2 jeeps and a trailer...:smiling::smiling::smiling::smiling::smiling::smiling:
Yeah, but the trailer won't need chains.:smiling2:PaulE
Love the cracked windshields. PaulE
