Halftrack to Halftrack
Hi Mike a great little tutorial thank you for taking the time for explaining step by step how you made the pulley wheel which look's spot on :thumb2:, I'll have to look into these templates.
Pete.
Mike. This gets more like a class in engineering :thumb2::thumb2:
John .
Pete.
Pete,
No problem, they are originally for re-scribing the panel lines on model aircraft.
Cheers, Mike.
John, Steve,
Many thanks for the comments, Steve, when you have AC/DC blasting away you do not need a mind :tongue-out3: just go with the flow. But in reality I try to set myself a goal and head there, more to see if I can do it.
Cheers, Mike.
Update,
Slow day today, must have had something to do with laying in and reading the new book till the early hours :nerd:.
But managed to add the jib stay brackets at the top of the jib, and begin to put together the hook. I would have had it done but just took my time while waiting for some thick sewing machine thread to arrive so that when the jib is folded/stowed I can get the sag on the 'cable'.
Also put the ducting in place and the 'pull' chord for the lights in the rear working compartment, look at the pic upside down to get the picture :upside:.
Jib Hook....
...Light ducting.
Enjoy,
Cheers, Mike.
Have to agree with Scottie most people wouldn't have bothered are even seen it come to that . I think a early night for you my lad.
Pete.
Pete.
The meds are on the way, and now off to watch an intelligent programme, The Chase, always give the wrong answers, messes with her mind.......
Wow mike, I can't believe I missed this one. You have 2 on the go then Sir? This is another work of art in the making. I just can't keep up with you buddy...I really do love all the little details you add!
Gotta see if I can find some of those template things here in the Fatherland…………..
Allen
Excellent details. Really good blog, full of good tips. PaulE
"Those about to rock. "
Takes me back to the N.EC when I was leaving a trade show, to be met by a train load of cheering denim clad fans. Earlier they had a sound check in the concert hall next door, when the cannon went off, so did all the fire alarm's where we were ! Mass exit,all good fun !
Nice hook by the way Mike.
John.
Allen
Allen,
Yep! sneaked this one in under the radar, had to find something to take my mind of the bridgelayer having counted all the dots on the wallpaper, started to join them up, but got a slap and my crayon taken away :disappointed:.
Panel Scribing Templates are the correct terminology I think, have a look under the aircraft tools bits. Just had a look on ebay but that came up $$$$, so should be available in Germany.
Many thanks for the comments, I will be dropping by your build later, think I have your cold.
Mike.
Update,
The light fittings are now in place, so work can proceed a bit more and added the flourescent light bulb tubes, but they will go in after the interior is painted.
The hook is just about finished, just a bit of cleaning up to do. I did replace the pully wheel at the end of the jib, the one in place looke a bit on the small side (photo later).
The odd angle of the plate is intentionable to add a bit of repair work. And that is it for today - now it is wheelie time on the AVLB.
Mike.
Outstanding progress on this unique project. I like your method on making the pulley wheels.
Hi Mike, it's been said before your eye for detail it truly amazing and the work you are producing is just stunning and I'm very happy you have come back to build this top class work :thumb2::thumb2::thumb2:.
Pete.
