Pilots seat first because that is sandwiched between the two fuselage halves then prime the other parts and off we go. Love using the xtracrylix paints they have a nice sheen to them, but you have to get the mix and pressure right or you will get clogging of the airbrush tip. The model has some fit and alignment issues and some of the instructions leave you to work it out for yourself so dry fit everything.
