Jakko’s 1/72 Spad XIII C.1 (Starter Set Group Build)
This is the Revell starter set of a Spad XIII C.1, built per the rules of the group build: nothing that didn’t come with the kit. That rather limited me, as it has just two colours of paint, so at the suggestion of @Tim Marlow, I used the tan plastic as the third colour in the camouflage and mixed the fourth from the other two.
8bdee83c-a87c-4831-8a25-f4cf1664123d-jpeg.337242
8b34a903-1a91-4bf0-8ac4-8b34d17c67a0-jpeg.337243
142ad67f-cb7c-4e31-9ae7-6d36aaf810d5-jpeg.337244
Unfortunately, this left no way to paint black or the light grey for the undersides, so I just left those off entirely :)
Wow Jakko,
This looks really good considering what you had to work with!!! Decals look great too. Still can't understand why there were only 2 colors in the kit...……….
Hi Jakko
That is a great result especially considering that the kit paints were woeful.
Thanks, but the kit is actually nowhere near as bad (or should I say: basic) as it looks at first sight.
That’s probably because they’re “printed in Italy” (as it says on the sheet) which probably means Cartograph :) Way better than the decals Revell used to have in the ’80s, that’s for sure.
Like I said before, I think it’s basically to get you started and encourage you to buy the other paints separately.
The paints themselves are very nice — they brush well and cover well. It’s just that you don’t get nearly enough colours :) If they’d only also put a put of light grey paint in there, it would have been much more useful. But the underside is supposed to be mixed from two colours, so I suppose that’d why they didn’t.
I’m actually fairly impressed by this kit — given its age, detail is far better than I would have expected had I known it before buying :) Sure, no need to bother with the starter set, really, and even for beginners it’s not actually one to recommend (both for the lack of paints and that the parts need a bit of work to fit well), but even just painting it properly and adding rigging would result in quite a nice model.
