BOATMAN's USS NIMITZ CVN 68 BUILD IN 1/144 SCALE
MAIN FUSE box in as she will have 5 different voltage circuts in an that's 12v '9v'6v' 3v'an 1.5 vcarrier build207.jpg
An in the above pic can be seen just one of the 3 relays that will be in her to manage power an the black box with yellow dails is a voltage reducer
an here can be seen the ESC'scarrier build208.jpg for the motors each one powers two motor's an another voltage reducer with the bow thruster in place
Here these these two unit called k7 an k8 work from the R/C all the lights on the ship there is a micro servo fitted below the unit an as its worked from R/C the cam's hit the micro knock on switches for on an off on each lights setcarrier build210.jpg
to show how it all comes to bits for a service
NOW on the island the ships pentant no. 68 lights up an it looked great when on the pond as the lights could be seen in broad daylightcarrier build225.jpg
An the strb side of the island could be unscrewed for again serviceing
an it just un pluged from the main island unit an in case you wonder what the purple stuff is its humbroll mashall as I found it turns like rubber the insalate live wires with a low voltagecarrier build227.jpg
