Rickety Bridge
scottie3158
Paul
Holbeach lincs UK
Paul
Holbeach
I am going to try and represent my M20 just passing over a wooden bridge that spans a small stream and a wide stream bed. It has been constructed from balsa and dowel. For the moment I have tried to show although not visible in the pictures the marks left by the bolts and nails used to construct it. I will try and find some small pins to represent them better later.
The reason for the bridge is I want tp practice taking my dio's up and not just flat scenes.
cheers
Scottie
Very nice.
Although to me it looks damn sturdy, great piece of construction.
Hey Paul,
I'm with Andy here my friend. The bridge is really sweet and well built. I can't wait to see what's next!!!
You should work for the council, sorry turn up, boom, boom
Cracking work, looks excellent!
Stunning work Paul.What was your inspiration? Was it a photo or a bridge nearby you?. Looks ideal for playing Pooh sticks. :smiling3: Looking forward to seeing the meandering stream underneath. Good luck with the rest of the dio
That is a great looking bridge Paul :smiling3:.
Ralph, Thanks fella.
Steve, thanks mate its a mixture of pictures from the net and verlinden bridge but I think it was a bridge design that was built by German engineers.
Hi Scottie
That looks very nice indeed. Looking forward to the next steps. What glue do you use for wood?
Hi Paul, great work on the bridge it doesn't look very rickety to me. I suspect you have a cunning plan :tongue-out2:. Will keep a eye on this one.
Pete.
Does indeed look like German engineer work. A fine job. Sometimes a Sharpie does fine for nails/screws. They just need a touch of red/brown rust streak on verticals if older. PaulE
Hi Scottie
Hi Jim, I just use normal PVA or a bit of superglue on small contact areas.
Pete.
Pete, I have a plan but I wouldn't call it cunning more seat of the pants.
Thanks Paul, that's a good point about the rusty bolts/nails.
Nice bridge Paul, would you rebuild our bridge?
Cheers, Jim
No worries mate if I have any balsa left over I will have a look.
Nice bit of miniature woodworking Scottie.
Thanks Mick.
The work continues on the base. The basic shape has been formed from foam blocks. This has then been coated with PVA and filler. When it had dried it got a dusting of mixed grasses. Then this was dusted with Tamyia flat earth to tone down the brightness of the grass. The strip you can see will hopefully represent a concrete plinth.
Next it is time to work on the vegetation.
Then the bridge received a base coat of dark drown ready for the next stages.
cheers
Scottie
THE bridge looks ok to me Scottie very nice build im followin your build as like the other guys say great work :thumb2::thumb2::thumb2::thumb2::thumb2::thumb2::thumb2::thumb2::thumb2::thumb2::thumb2:
chris
